anyone know anything about Pontiac motors?
Old 07-03-2009, 08:19 PM
ElkySS's Avatar
Default anyone know anything about Pontiac motors?
my dad has a 1972 Pontiac Grandville with a 455 in it. its getting a little tired and hes talking about pulling it to get rebuilt in winter. i have no clue how to build pontiac motors. does anyone know a good shop in or around houston to build this thing for us? we want atleast 450 hp out of it
Old 07-04-2009, 06:49 AM
cooter brown's Avatar
Tommy Costales @ Houston Engine and Balancing - I had a '73 Grandeville with the same motor and he turned it into a beast! (If a 5000 lb car can be called that...) - all I know I sure spent alot of money on tires for the rear of that thing.....
Old 07-04-2009, 09:12 AM
BAD2000TA's Avatar
455's are great! Lots of torque. Go to the Performance Years Forum for lots of info on Pontiac-related stuff. Very easy to get 450 horse out of a 455. Edelbrock heads or Kaufmann Racing heads with a good cam will give you some good, reliable power. Here's the link to the PY forum:
http://forums.performanceyears.com/forums/
Old 07-04-2009, 09:58 AM
demonpixel's Avatar
There's also Owens Racing; I've talked to two or three people from the PY forums and they've had good experiences with their Ponchos and Owens. You/your dad might also want to check out this book: http://www.amazon.com/How-Build-Perf.../dp/1884089674
Everyone I know that owns a Pontiac has that book.
Also, this is a good article on a Pontiac 400 build: http://www.highperformancepontiac.co...ine/index.html
I know it's not a 455 but it has some good info that might help to familiarize you with these Pontiac engines (455s and 400s are the same block).
Old 07-06-2009, 11:36 AM
quicksilver383's Avatar
All good info above. The 455 is perfect for the Grandville. Just make sure that whoever builds it DOES KNOW Pontiac. PY is a great site as well, there is a guy there that races a 74 455 Grandville 4550 lbs 12.08 E.T.. 110.86 MPH...60 ft 1.71 Fun stuff with a big car like that!
Attached Thumbnails anyone know anything about Pontiac motors?-20090411114843-1-.jpg
Old 07-06-2009, 11:45 AM
GreenS-10's Avatar
Houston Engine and Balancing. Built two motors (one mild and one high HP) motors for the GTO race car. one was a stock blocked 462 that made about 600HP and the other was a 512 IA2 blocked motor that makes 900hp. Butler Performance is a good place for parts Also
