quick ARP head stud install question
Old 07-04-2009, 01:19 PM
Tally TransAm's Avatar
Default quick ARP head stud install question
i know you are supposed to use moly lube when torquing the nuts onto the studs, but are you supposed to use moly lube when threading the studs into the block or do you install them dry
thanks
Old 07-04-2009, 01:21 PM
JPH
JPH's Avatar
thanks
You can, but I use alittle oil on the threads myself, then run them in finger tight and a hair past.
Old 07-04-2009, 04:14 PM
conan's Avatar
I used the molly lube on both the threads in the block and the nut threads.
Old 07-04-2009, 07:52 PM
KCS
Moderator
KCS's Avatar
You use moly anywhere there will be friction. That includes threads, both sides of the washers, and underneath the nut.
