Required parts for pinion seal replacement?
Old 07-05-2009, 07:56 PM
Tom565's Avatar
Default Required parts for pinion seal replacement?
My pinion seal just started squirting oil everywhere under my car so I am going to replace that myself. I used the search and I feel confident that I can do it. I will also be replacing the oil too and inspecting the gears. I have some parts questions though. I will be going to PepBoys tomorrow to get what I need but I want to make sure this is everything so I only have to make one trip there:
2- Quarts 75w-90 oil
1 bottle of limited slip additive (I have a Torsen but I am still going to add it)
10 bolt rear end gasket
Pinion seal
**Do I need a new pinion nut and crush sleeve? I read somewhere that I do but I am not sure.
Old 07-05-2009, 11:27 PM
goldmecham's Avatar
get a new crush sleave or get a solid spacer and use that. and deff get a new nut unless you get the solid spacer then u just can use locktite
