Are these the right AC Delco Part numbers for the front O2 sensors ?
Old 07-08-2009, 01:29 PM
Pro_built7's Avatar
Default Are these the right AC Delco Part numbers for the front O2 sensors ?
Just wanted to check and make sure these are the right oxygen sensors for my car.
99 z28
need 2 new FRONT O2's. (square)
LS1 O2 oxygen sensor (98-02) (AC-Delco #AFS97), both RH = 25312196
LS1 O2 oxygen sensor (98-02) (AC-Delco #AFS98), both LH = 25312197
found this in a search ^^
www.gmpartsdirect.com has them for about $78 each.
is this the cheapest place to buy delco?
I dont want to run anything but AC delco.
thanks !
Old 07-08-2009, 03:39 PM
Pro_built7's Avatar
can somebody check for me real quick?
Just don't want to spend $160 on the wrong parts
Old 07-08-2009, 03:44 PM
Blk99ek's Avatar
a guy on ls1lt1.com posted the same thing for his lt1
Old 07-08-2009, 03:50 PM
LS6427's Avatar
99 z28
thanks !
You'll be lucky to find any more REAL authentic AC Delco 02 sensors. GM is now using Densos as their choice. You will buy AC Delcos and you will pull Densos out the boxes. My friend who is the parts manager at a Pontias dealership verified that.
You're throwing money in the trash by buying AC Delcos from the dealership. You might get lucky and find some at places other than the dealers, I'm sure there are still some AC Delcos floating around. Waste of money.
I put Densos in my car a few months ago. BUT....I ordered AC Delcos. The guy at Bennett brought me my two AC Delco boxes and I opened them to find Densos in there. I then asked him to bring me two Denso 02 sensors in Denso boxes.....IDENTICAL.
He had no clue why Densos were in there, thats why I immediately called my friend to verify it. I only went to Bennett because they had a special 15% off offer so it was $40.00 cheaper than even my friend could do at the dealership.
The Densos are BETTER 02 sensors than GM originals too. But I won't get into that.
Go here and buy Densos for about $45.00 each.
www.rockauto.com
Old 07-08-2009, 09:36 PM
Pro_built7's Avatar
dude... you rock. thanks man
Old 07-08-2009, 09:39 PM
Pro_built7's Avatar
wait... which ones do i need ?
Quick Reply: Are these the right AC Delco Part numbers for the front O2 sensors ?
