Front End Parts: What is this that fell out?
Old 07-08-2009, 04:51 PM
anon1's Avatar
Default Front End Parts: What is this that fell out?
Hello,
I have a 1997 T/A and when closing the hood today the following part fell out from the front-end somewhere. It is 3/16" thick and looks like a shim or spacer? Can anyone please tell me where it goes?
Thank you.
Old 07-08-2009, 05:38 PM
Wing Zero's Avatar
Where on the car did fall under? It could be from the front fender.
Old 07-08-2009, 08:04 PM
anon1's Avatar
Sorry, the closest I can get is under the front end somewhere. Between the tires towards the right side. But I think I heard it clank off of someting or two on its way down so it might have bounced.
Do they use thick shims like this on the fenders?
Anyone else? Thanks.
Old 07-08-2009, 08:50 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
More than likely came out of the fender
Old 07-08-2009, 09:31 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
It's a shim from one of the fender bolts. It could have been on any of the fender bolts, but more than likely towards the rear for door/fender alignment.
Old 07-10-2009, 03:07 PM
anon1's Avatar
Thank you everyone. It was a fender bolt shim.
Right side, front one just rear of the headlight. I would have never found the missing spot without you, as the shim is hidden behind the bolt up under the lip of the fender.
Every fender bolt, both sides, was a little loose. Shim falling out, and all loose bolts on a 17k mile car?
Quick Reply: Front End Parts: What is this that fell out?
