Clunking in the rearend?
I have a 98 camaro and everytime i hit a bump going down the road or even roll off my drive way it clunks in the rearend nothing is loose i have had it on the lift and shook stuff and checked nuts and bolts but cant find anything loose. A mechanic road in it and said it might be the rear upper shock mount is loose or broke. any ideas?
Is your Camaro lowered at all? If so make sure you have enough clearance between the exhaust and the axle where it wraps over top of it because mine was hitting before i raised it some more to keep it from hitting.
My car is doing the same thing
I checked under the car and nothing moves/ clunks I have new LCA, Panhard,Trans mount tq arm and he dam thing still clunks WTF
i checked the shocks and they are solid.. the exhaust might be the bad guy.
