4:10 question
4:10 question
Im a retard and know nothing about rear ends.
is this what i want for 410s?
http://www.summitracing.com/parts/SU...odel|GM+7.5+in.
and is this a good price?
That is a pretty good price on just the gears. Have you considered replacing the bearings, also I didn't see if shims came with those gears you will need them to set up the pinion depth and back lash. I just bought a whole kit from Texas Speed. Came with Motive gears, shims, bearings, a T.A. girdle cover, fluids and everything.
shims will come with the rebuild kits, i have used the Ratech kits in the past with good luck. I think they are $80 or so without wheel bearings and seals or slightly over $100 with them.
