tr6060 installed in my 98 Camaro!
Old 07-10-2009, 07:57 PM
Lust4Thrust's Avatar
Default tr6060 installed in my 98 Camaro!
The TR6060 is now in. (Dave @ D&D performance a sponsor here was very helpful). I couldn't trust my stock T-56 (although it gave me no issues period, with 700 hp, and 780 ft-lbs at the wheels I wasn't confident on its survival).
This Required:
1) modifying the consol, as the shifter was about 3" farther forward
2) Different shifter lever, (used one from a chevy truck 4 wheel drive lever, reversed, and bent). Haven't fabricated an adapter to use my stock shift **** yet. My hurst shifter hit the radio couldn't make it fit.
3) Required shortening my driveshaft, from 40 3/4" to 37 5/8" yoke caps to yoke caps. The TR6060 is 3 inches longer too!
4) Required a plug for the mechanical speedo (shipped with just a rubber dust plug)
5) Required an ford style electronic speedo connector (found one from a tempo to match up).
QTP bellhousing also used, minor mod required to clear non stock exhaust (APS driver side turbo).
It was tight as now the driveshaft loop is right around the 1350 U joint.
Anyone else with any experience on this tranny?
1998 Camaro SS. APS turbo (base) with 402 LS2
Attached Thumbnails tr6060 installed in my 98 Camaro!-tr6060-98-camaro.jpg   tr6060 installed in my 98 Camaro!-shifter-tr6060-1.jpg
Old 07-10-2009, 08:02 PM
nukeemall454's Avatar
not a direct bolt on then huh still cool have you gotten a chance to drive it yet
Old 07-10-2009, 08:04 PM
Drives fine, no issues so far, will know more once I hit the track.
Old 07-11-2009, 09:19 AM
thesource's Avatar
Yeah it sucks that Tremec didn't offer the unit as a direct replacement to the T56. IMO, that will be the deterent to people buying them over a built T56.
Old 08-19-2009, 11:09 AM
Big_Bird_WS6's Avatar
mine didnt seem to fit that bad.
i am thinking of making a shifter like this.
would this help you with yours?
pm me.
we need to get this figured out for all the f-body guys.
Quick Reply: tr6060 installed in my 98 Camaro!
