Disappointed With my results!!!!
Old 07-10-2009, 09:04 PM
96formulabird's Avatar
Default Disappointed With my results!!!!
hey guys went to the track tonight. i threw the DR's on the back and i put bilsteins out back hoping to cut a good enough 60ft to get a 13 flat. my best tonight was a 13.652 @101. my 60ft was 2.049. in my sig when i ran a 13.4 @100 was on crappy street tires. maybe it was slightly because of the weather tonight why i did not see the results i was hoping for. it was about 85 degrees and muggy as crap. To make matters worse on my last run i messed up the rear. i have no more posi. it a single tire screamer now. it gives me an excuse to throw some 3.73's and a girdle at the 10 bolt lol. just thought i would share this with everyone. any input on this would be appreiciated. o by the way the 60ft on the run in my sig was a 2.1. also my launch was acctually better tonight then any other time. so idk what i can do about that. thanks in adavance for any good or bad comments.
Old 07-10-2009, 09:12 PM
BSmiff's Avatar
You need better air to run better N/A. So its time to put the car down for some repairs/more mods. Id recommend a converter/tranny cooler and an EWP if you dont have one already.
Old 07-10-2009, 09:18 PM
yeh i figured it was a little to do with the air. yeh i guess since the rear is messed up its time for gears, girdle, tranny cooler and thats it for now lol. by the end of the year hopefully some suspension and a stall which is becoming a must. even tonight with DR's i could only take the stock converter to bout 1300rpm before it would start to spin the tires over. well one of them anyway...
Old 07-11-2009, 12:35 PM
OddballLt1's Avatar
The DA has alot to do with it. When I had my stock converter i could only launch at 1300, so your right there. How big are the DR's?
Old 07-11-2009, 04:31 PM
the dr's are like factory size tires. there mt et streets in size 255/50/r16
Old 07-12-2009, 11:46 AM
Goat2NV's Avatar
Was this at Capitol Raceway??
Old 07-12-2009, 09:29 PM
OddballLt1's Avatar
how much weight have you pulled out?
Quick Reply: Disappointed With my results!!!!
