Notices
00-02 LS1 TPS and IAC sensor WANTED
Old 07-13-2009, 06:26 PM
Orr89rocz's Avatar
Default 00-02 LS1 TPS and IAC sensor WANTED
In need of a working good condition TPS and IAC sensor for 00-02 stock throttlebody... LS1.
Let me know what you have and how much.
Old 07-13-2009, 10:55 PM
DemonInside's Avatar
i didnt think there was a diff between the years i have a tps and iac from a 98, let me know!
Old 07-14-2009, 04:36 PM
Orr89rocz's Avatar
i tried search around and apparently there were different throttle body part numbers and iac sensor part numbers so i'm not sure. TPS i'm not sure if thats the same or not
I believe i have the 00-02 factory throttle body since it has the blue spring and not brown
Old 07-14-2009, 10:27 PM
tps's are the same i checked at autozone today when i was there, iac's have diff part numbers but i have used my 98 iac on a newer throttle body because i wanted the smaller throttle cam,the part that the throttle cable connects to on the tb is smaller then pre o1's
Quick Reply: 00-02 LS1 TPS and IAC sensor WANTED
