steering column help to get part number
my z28 steering column is done....i have one on hand but i dont know if it will work..can anyone tell me what it fits by this part number on it.... 26025285,,,thanks
93-02 works u can get one from the junk yard and rebuild yours with the guts from it or just swap it in just have to make sure the multifunction switch is the same or swap it with your multifunction switch so u will still have cruise or or not and if u have steering wheel controls just swap the wires over also if u get one from a junk yard re use your ignition cylender so the vats will work still and wont have a problem with it not starting when your all done
