Oxygen sensor removal help!!!
Thank you guys, this is my first attempt at a header install, I am doing a set of edelbrock shorties (I know about LT's) Everything has gone surprisingly well, I got the o2 sensor out it was a little buggered up (dealership) but I was able to get it back in and solid including the anti sieze. Just waiting for my gasket set for the install. I was going to use anti-seize on the header bolts as well, or should I? I noticed a yellow type powder on the bolts when I took them out. should I use that stuff instead? Thank you for your help.
A dab probably wouldnt hurt them, but not alot b/c you dont want the bolts backing out anyway. Also, the headers arent something you are going to be removing frequently anyway (hopefully).
Good luck on the rest of the install, I just got my new LT's this morning...now gotta get a y-pipe.
