Car smokes when started???
Old 07-14-2009, 08:32 PM
skeeters65's Avatar
Default Car smokes when started???
My car smokes a little when it cold starts.. Not much just for a few seconds..
Well my car has been sitting for 2 weeks with a bad clutch. Today I started it up and it smoked like a chimney for about 20 seconds.
It runs very rough when it smokes like this..
It doesn't use any oil, almost positive it is fuel. Thats what my tuner says. It is due to the big cam. MS3!
Any reason why it would smoke more after sitting for 2 weeks??
Thanks
Old 07-14-2009, 09:18 PM
eseibel67's Avatar
Valve seals.
True, you may not be burning oil. But it doesn't take much oil leaking past the seals to make a pretty nice blue puff on startup.
Old 07-14-2009, 09:24 PM
SOMbitch's Avatar
Originally Posted by eseibel67
Valve seals.
X2. If it clears up after startup this is your most likely culprit. Good time to do springs if you need'em....
Old 07-14-2009, 09:53 PM
Rossi396's Avatar
What color is the smoke...!?
Old 07-14-2009, 10:41 PM
gsxr1k2's Avatar
Ya mine smokes a little bit too............... might have something to do with its nose candy addiction and the big pimp bitch slapping its *** down the 1320.
