4.10's and a 100 shot?
Old 07-15-2009, 11:16 AM
Brettz28's Avatar
Default 4.10's and a 100 shot?
What is yall's input on 4.10's and a 100 shot? All motor the car runs 11.9-11.7 @ 114. Running a 27" tall tire (hoosier DOT 27/11.5/15). Haven't sprayed the car but 114mph is the top of 4th? Just wanting some thoughts or knowledge on what to do? Ex. shift to 5th NOT spraying, coast through the traps, change gears ect...
Old 07-15-2009, 12:50 PM
6LTRiceater's Avatar
You should be ok. That 100 shot will probably put you at about 120-121 mph, and that's 6200 rpm with the 27" tire and 4.10 gear. I would not bother using 5th gear, you don't need to.
Old 07-15-2009, 01:05 PM
gyrene2003's Avatar
What are your mods, just curious.
Old 07-16-2009, 10:07 AM
Brettz28's Avatar
Full boltons, Spohn suspension (everything but K-member), Mild Cam, Strange 12-bolt with 4.10's. QA1's all around. N20 and thats about it I think.
