Car doesnt want to start (wierd)
Old 07-15-2009, 08:14 PM
cryptnosis's Avatar
Default Car doesnt want to start (wierd)
whole story now:
Friday last week had my car tuned by vengence racing (they did great job), we had to replace the fuel pump and filter that day as well. pressure was at 62lbs. Sunday the car was driving fine then when i pulled up to the house it didnt want to hold an idle anymore. I then shut it off and tried to restart it. NOTHING AT ALL, not even a cranking sound. I checked the battery and it was fine, tried jumper cables, no go. Thought maybe it was hot, so i waited. 10 mins later it rolled over but it spent 3-5 seconds to crank up. Next morning, the car did the same thing, felt like it didnt want to roll over, but it would eventually, and once it rolls over it idled ok, as soon as i put it into gear it drops my RPMS to 400ish and dies eventually. I replaced all spark plugs and wires, same thing. When it does crank up, and i pump the gas their is a huge delay and sometimes backfires. any suggestions? I want to check the ICM but dont know how to remove it or even check to see if its reading the keys resistor. Any help?
Old 07-15-2009, 09:07 PM
matrik's Avatar
Did u replace the filter before or after tuning? Any trouble codes?
Old 07-16-2009, 03:25 AM
cryptnosis's Avatar
replaced the filter the same day as the tuning. right after they put in a new 255lph pump. no codes, nothing out of the ordinary on the cluster. no blinking security. nothing.
Old 07-16-2009, 09:25 AM
TooLateVTEC's Avatar
How was the oil pressure?
Does the oil look ok?
Old 07-16-2009, 10:22 AM
Jeff Smith's Avatar
did you take off the ground cable??? Try check ground
Old 07-16-2009, 11:03 AM
mook99ta's Avatar
also check for a vacuum leak that could explain the rough/low idle speed.
Old 07-16-2009, 11:38 AM
cryptnosis's Avatar
Oil pressure good. Fuel pressure good. Which wire to check for a ground? as far as a vacuum leak, the only spot i know of would be in the back of the intake.
Old 07-16-2009, 12:39 PM
sscamaroburn02's Avatar
idle issue sounds like a vacuum leak. check all hose connections near back of intake
Old 07-16-2009, 12:51 PM
1SLwLS1's Avatar
I wouldnt spend too much time checking for a vacuum leak, whenever my batt dies(often as of late) the idle is horrible for about 30 minutes. Then it smooths out to normal
Old 07-16-2009, 02:32 PM
svshawk03's Avatar
If its a walboro pump then thats the issue, they are junk. check the fuel pump relay
Old 07-16-2009, 10:20 PM
cryptnosis's Avatar
it is a walbroro pump. where is the fuel pump relay (is it the one that connects to the back of the rear seat. It smells really RICH. I will post more tonight (we are scanning it)
Old 07-17-2009, 06:36 PM
eallanboggs's Avatar
So do you have a cranking, starting or idling problem or all 3? Don't transpose the terms crank and start. They are different and if you use the wrong word your question gets confusing. I'd go back and check fuel pressure again since that was one of the last things you worked on. You can have an assistant turn the key while you use a DVOM to monitor the BATT voltage while cranking. It shouldn't go below 11Vdc across the POS and NEG terminals. You can also do Voltage Drop tests at the BATT and at the starter. The drop should be minimal(in the millivolt range). Also check for 12Vdc directly at the starter motor when the key switch is in the START position using a DVOM. Have an assistant crank the engine while you do the check unless you have a remoter starter switch. There should be minimal voltage drop during this test. If you don't know how do to voltage drop testing google it.
Old 07-19-2009, 12:59 AM
cryptnosis's Avatar
Problem is located in the tank, we traced it through and i have pressure (62lb, a little high, but not worried). We are tearing into it on monday will update results, i am thinking the pump.
Old 07-19-2009, 12:03 PM
un17real's Avatar
+1 i have ordered 2 replacement walbro Pumps and every time i drop it in it acts lke they are full of dust and they were made way to fast and not tested fu$k those pumps i would go to auto zone before i would buy another one of those pumps.
Old 07-21-2009, 01:17 AM
cryptnosis's Avatar
Found problem. Problem was the tubing that runs in the tank it was desintigrated in the tank. replaced it and it works like a champ again
