Is there any stronger u-joint options??
Old 11-17-2003, 09:56 AM
BLKWS6's Avatar
Default Is there any stronger u-joint options??
blew out the rear u-joint (1310/1350) at the track. Is there any better u-joints or any solutions to this? aside from a cutom DS with the full 1350 joint?
Old 11-18-2003, 01:28 PM
A BAD T/A's Avatar
Various mfr make HD joints, Borg Warner, Spicer, etc. Go for a joint WITHOUT a grease fitting for max strength. That grease hole in the joint weakens it.
However, now you have to manually grease the joint every 20k or so (Not a fun job!).
Good luck!
