Fuel pressure problem????
Old 07-18-2009, 08:31 AM
Y2KSS's Avatar
Default Fuel pressure problem????
Went to the track last night to try out my new wet kit and it didn't pick up any time on the 100 shot. I did notice at wot when spraying my fuel pressure dropped to 35 psi. When I was not spraying it stayed at 58 psi at wot. Does this sound like the fuel pump?
Old 07-19-2009, 10:29 PM
blown 99's Avatar
possible to be a pump, filter, regulator, wat kind of kit do you have
Old 07-19-2009, 11:02 PM
jmill96Z's Avatar
Looks like you're running out of pump. You're not on the stocker are you?
Old 07-20-2009, 08:27 AM
Y2KSS's Avatar
Its a cold fusion wet kit with the 100 shot jets in right now and yes it is a stock fuel pump.
Old 07-20-2009, 08:41 AM
ATVracr's Avatar
May also be getting voltage drop from the noids.
Drop a walboro in and see if it fixes it.
Old 07-20-2009, 08:49 AM
ShiznityZ28's Avatar
Probably that 15 year old fuel pump..... but change the fuel filter while your at it. whats voltage like at wot on the juice? NA?
