TH400 needs rebuild what parts to use?
I have a TH400 I got in a trade that needs a rebuild, it slips a little once it gets warm. What parts does everyone use in their TH400? I figure on a full rebuild so need info. Also what convertor and flexplate should I use since its going in a 6.0 S10 with 4.10s?
i cant tell you what converter. but tci makes a nice flexplate thats sfi approved. you can find the part number one of the write up in the stickies.
i am running:
alto red eagle clutches through out.
kolene steels.
34 element sprag(may need to get a new drum depending on what kind of sprag you have already)
upgraded pump spring for greater pressure.
with sonax boost vavle and sleeve.
get a shift kit there easy to install.
hope this helps.
i am running:
kolene steels.
hope this helps.
