Swapping 2000 5.3 into 89 rcsb
Old 07-20-2009, 08:26 PM
Caseman221's Avatar
Default Swapping 2000 5.3 into 89 rcsb
Hello guys,
I am new to your forum and am hoping you guys will be able to help me out. I have a 89 chevy 1500 with a old used and abused 305. While in the process of redoing the body work i scored a 5.3 Engine out of a 2000 chevy 1500 with 60xxx miles.
I am making a little list of parts that i am going to be needing. So far i got Motor adapter plates. and a 4l80e trans.
The fuel system in the truck needed to be replaced before the build so i went ahead and ordered a RCI 17 gallon Fuel cell. But i need some help on what to get for lines and a fuel pump/ filter setup.
I look forward to hearing and posting more as i get under way. Thanks for the help in advance.
Caseman
Parts list.
4l80e tranny
5.3l 2000 chevy 1500
If this is the wrong section i apologize ahead of time.
Old 07-26-2009, 04:23 PM
bustac's Avatar
Default fuel system
I hear a lot of people using an external walbro pump along with a corvette style filter/regulator. I think your motor if it is a 2000 has regulator on the rail.
I think you also need to have your ECM OS merged to a 4L80E configuration...
