Drag Racing Tech - what harmonic balancers are people using?
Taubr Unit
07-20-2009, 09:04 PM
Theres a lot of different price ranges on them, $20 for used stockers, $150, Summit house brand to $200ish TCI brand to $380 ATI ones. For the most part im trying to be somewhat realistic here and trying to get my car finished without buying John Force parts that is over kill. Thought about buying a stocker now to get my motor finished and upgrade later on down the road or buy a mid grade one now and use it even later down the road. Dont think i need a fluid damper....or do i? Is this a perticular part i can go middle of the road and be fine? Whats everyone else using and how does it work? I only plan on spinning to 6500rpm-ish so no 7k pulls for me.
SLowETz
07-20-2009, 09:49 PM
You'll prolly get a bunch of different answers as what is used and which is best.
Personally, I went w/the ATI Super damper on my new motor. It has a good track record.
Harmonic frequency vibration isn't your friend whether you're spinning to 8500 or 6800.
You've already spent a good chunk of cheese on a new build, don't skimp on the balancer..... get the best you can afford.
4bangermustang
07-20-2009, 11:17 PM
ATI.
carefull when ordering, they suggest a different rubber on a race motor, though I tihnk a bunch of guys on here use the stock rubber that is offered.
ssman00
07-20-2009, 11:31 PM
i went with the summit. it seems to be a quality piece
4bangermustang
07-20-2009, 11:46 PM
keep in mind, per NHRA rules, 10.99 or faster you are to have an SFI approved one. I believe ATI is the only one with an SFI rating? I could be wrong on that, not sure.
SPEEDYws6
07-21-2009, 01:02 AM
Get the ATI, I didn't the first time and will end up having to soon.
Fireball
07-21-2009, 06:03 AM
ATI for sure
dschmittie1
07-21-2009, 06:34 AM
I have an ATI on mine
built408
07-21-2009, 10:01 AM
I have the TCI one, it has an SFI stamp on it.
night ryder
07-21-2009, 12:51 PM
the summit pulley is sfi approved. that is what i will be running, but have not tested it past 6k yet.
ATwelveSec02Z28
07-21-2009, 01:45 PM
I have the ATI SuperDamper on mine...ATI will recommend different rubber, and the largest possible diameter for race engines. I had to go with a 6" due to the GMPP dist. cover
http://i280.photobucket.com/albums/kk166/LSWon02Z28/IMG00014-20090709-2013.jpg
BlackScreaminMachine
07-21-2009, 01:59 PM
WHat ever you get, make sure it has a SFI rating that meets your ET requirements and ATI is a great piece.
jg04222
07-22-2009, 08:22 AM
ATI is the one to get. Just make sure you get the one for your application (rpm's, engine stroke length, etc). I don't know about the ls1 balancers, but for a gen 1 smallblock they have different diameter and different elastomer o-rings in them for different applications.
veee8
07-22-2009, 09:49 AM
ATI here.
Pro Stock John
07-22-2009, 10:59 AM
Ati...
tomz28
07-24-2009, 12:19 AM
W2W back in the day did a test on this with some big $$$$ behind it the sensor they used to test the balancers on a engine cost over 100k and the ATI by far was the best one
firefighting1101
07-24-2009, 09:01 PM
man i have a slp underdrive on my car, but after reading this thread i may sell it and buy an ati...
TJ
07-25-2009, 10:14 AM
i was told by ati that anything over 600 crank hp must also use the stock diameter pulley.
the 10 or 25% underdriven will not cope with harmonics well in higher hp engines.
LSPerformance
07-25-2009, 05:12 PM
I use only ATI.
