Adjusting Ebrake!!
Adjusting Ebrake!!
I’ve now tried to adjust my ebrake on two occasions and both didn’t work out as planned. I took the time to research how to adjust via the star adjustment thing at the base of the rear wheels. It seems that the passenger side doesn’t wont to engage at all regardless of what position the ebrake handle is in. This whole issue started after taking my car into a retarded shop where they didn’t put my ebrake down to work on my whiny rear end which they installed.
The hand brake cable on both of the wheels move the lil tab thing. But only the drivers side pushes the ebrake pads... The passenger side does not move the ebrake pads at all
Have you taken the rotors off and check the life of the e brake shoes or pads? I cant say I have ever been able to get my e brake to work as good as it was when I purchased the vehicle.
Like you I did the adjustment, but it only helped so much, the e brake pads dont look so good so I'm attributing that as part of the issue.
I got on it more than a few times ( pulled it 80mph and did a few spins) and ever since then has barely enough grip to keep the car from rolling. Yes very stupid. I still cant believe I had the ***** to do that and came out of it with no issues!
Now it's just a parking brake
