Overdriving a D1-SC?
Old 07-22-2009, 01:53 PM
'Trust''s Avatar
Default Overdriving a D1-SC?
I know it isn't *advised* but does anybody know how much I could overdrive the blower quote unquote "safely". I'm spinning it 59,963 RPM's at 6,500 RPM's at the motor. I'm thinking of getting a 3.1" pulley made which would spin it to 65,765 RPM's, and the blower is rated at 62,000. Anybody have any thoughts? Physics wise if everything is balanced correctly (and I imagine it should be being capable of spinning to 62,000 RPM's) is the extra 3-4,000 RPM's to the blower acceptable?
Old 07-22-2009, 01:57 PM
AFASTYZFR1's Avatar
after what I have read, I wouldn't.......why not just spin motor a little higher than 6500?
Old 07-22-2009, 02:02 PM
'Trust''s Avatar
It levels off about 6300 RPM, I'm not sure if that would help?
Old 07-22-2009, 02:06 PM
AFASTYZFR1's Avatar
well I have heard the spinning blower to max won't help either....just starts to create a lot of heat
Old 07-22-2009, 02:08 PM
Mr.Big's Avatar
it helps a ton, main key is better bearings... and you can spin it MUCH more
Old 07-22-2009, 02:23 PM
'Trust''s Avatar
Who would install these bearings?
Old 07-22-2009, 02:26 PM
T/A KID's Avatar
More info please
Old 07-22-2009, 02:27 PM
Awake455's Avatar
Lol, I'd guess not procharger as they don't recommend it for over 62,000...and frankly I'd hate to risk running it that high. Their strong urging would likely be for you to upgrade to an F1.
Old 07-22-2009, 02:28 PM
'Trust''s Avatar
Well I know Procharger wouldn't lol, I wonder who would? If it is balanced it should be able to spin high enough? Also, a lighter blower spinning faster is more efficient than a heavier blower spinning slower isn't it?
Old 07-22-2009, 02:34 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Bob has told me he's had experience in people overspinning prochargers before. I'd give him a call. I doubt you will be hurting it too much man.
Old 07-22-2009, 02:40 PM
Louis's Avatar
What a ****
Old 07-22-2009, 03:51 PM
BigRich954RR's Avatar
I know a few people over spinning there F1 so far there still running. Wish i could help more
Old 07-22-2009, 04:42 PM
'Trust''s Avatar
^^ do you know by how much?
Old 07-22-2009, 04:49 PM
Mr.Big's Avatar
over spun my P1 for 30,000 miles with zero issues, made 787 rear wheel... I'd say that's a decent amount for a P1, no issues with IAT's. The bearings can be changed by anyone with a decent mechanical back ground, and a set of hand tools. ABEC 9 bearings are better, and ceramic bearings for the ballers...
not all bearings have to be replaced, you could just replace those bearings after the transmission (the bearings that spin much faster i.e. prop shaft) if you chose to...
Old 07-22-2009, 04:51 PM
Mr.Big's Avatar
Originally Posted by Louis
What a ****
I try to get these things designed and going, but nobody wants to market the bearings or "simple" adjustable restrictor, I don't understand it... though I have seen cad drawings!!!
Old 07-22-2009, 05:37 PM
'Trust''s Avatar
Any idea where I would source the bearings or figure out which ones I need? I know ProCharger isn't very helpful in this matter.
Old 07-22-2009, 05:51 PM
Louis's Avatar
Oh yea!! Me too!! how much did you over spin the P1?
Old 07-22-2009, 05:52 PM
Rickys S/C Z28's Avatar
i would just pm Mr. Big
Quick Reply: Overdriving a D1-SC?
