B&M Pro Stick Intall, Do I need 2 cables?
Old 07-23-2009, 10:46 AM
Black94Z28's Avatar
Default B&M Pro Stick Intall, Do I need 2 cables?
I bought a used pro stick out of who knows what car, but i coverted it to the 4 speed. Took the stock shifter out last night, as saw there were two cables going to the shifter. One has a hole off to the left about an inch away from the shifter and the main cable Im guessing goes all the way under the dash. My friend has the same shifter on his 70 Camaro and is only using one cable, so since I have two, which one do I use and whats the other one for?
Old 07-23-2009, 10:58 AM
Gingervitis Addict
slow67's Avatar
The other one is the column lock (where it won't come out of park unless the key is on and your foot is on the brake).
Old 07-23-2009, 10:28 PM
Black94Z28's Avatar
So can I leave this off or do I need it?
Old 07-24-2009, 09:51 PM
Black94Z28's Avatar
As long as Im ok with track tech, I dont really care if I have it or not. I just want to make sure the car will be able to work without it.
Old 07-24-2009, 10:04 PM
themack56's Avatar
Originally Posted by black94z28
as long as im ok with track tech, i dont really care if i have it or not. I just want to make sure the car will be able to work without it.
i think you should be fine. When i do my a4 conversion i wont be putting that one.
Old 07-26-2009, 05:44 PM
Gingervitis Addict
slow67's Avatar
The pro stick doesnt have a provision for it.
Old 07-26-2009, 09:54 PM
Black94Z28's Avatar
Ok, so ill just run the one cable, i have the 3 foot cable, that should be ok right? or do I need a longer one? I'll need to pick up a N safety switch or can I just make the factory one work somehow?
