HELP! Houston Area: Where can I find/purchase 4" aluminum pipe/tubing w/a 90º bend?
90º bend
Houston area
It doesn't have to be polished as I can do this at home. Here's a pic of what I need, however, the pipe in the pic is 3.5", I need 4".
The pipe will have to be trimmed to fit, so I don't need it a particular length.
90º bend
Houston area
Send me exact dimensions and I will get it monday......Do you need 4'' od or id and will a 36'' peice be enough or more??? What gauge ...how thick???
I wouldn't think a muffler shop would carry aluminum, but I could be wrong. Thanks for the tip, I'll call around.
I'm going to guess 4" OD and that should be plenty long enough. When you say 36" do you mean from one end to the other measuring with a square or along the pipe with the radius?
The piece I just bought was 3mm thick which is .118" thick.
