4" exhaust guys....what torque arm??
Old 07-26-2009, 09:38 AM
theblur98ss's Avatar
Default 4" exhaust guys....what torque arm??
Just curious what torque arm you 4" guys are running. I'm doing 4" out the back but my BMR tunnel mount TA is dead smack in the way. The only thing I can see to do is get a regular style TA with the relocation mount. I should be able to sell my current mount and TA and at least brake even on the deal. Another option was to cut out part of the crossmember and redo it around the exhaust with plate but not sure how well that would hold up. Thanks for any opinions or pics of setups.
Old 07-26-2009, 09:52 AM
2001WS6Vert's Avatar
I have the Midwest short arm, I did have to cut and modify the torque arm crossmember to make it work.
Old 07-26-2009, 10:50 AM
Restricted User
98Z28CobraKiller's Avatar
I use the adjustable tunnel mount Jegster.
Old 07-26-2009, 01:16 PM
ak95ta's Avatar
I use this one from Spohn http://www.spohn.net/shop/1998-2002-...ersY-Pipe.html and it clears the 4" mufflex exhaust just fine.
Old 07-26-2009, 01:18 PM
I had never seen the jegster setup. That would work perfect clearance wise. I'm a little leary of the design though. Read a couple bad reviews here too. The car won't be raced a ton and I'd brace the inside of the tunnel with some plate. I didn't like the pic of the one bent in half though.
Old 07-26-2009, 08:36 PM
crf538's Avatar
i have this same setup and got a 4 inch pipe through without modification, its close but it clears
Quick Reply: 4" exhaust guys....what torque arm??
