Leaking axleshaft. Moser 9", Common?
Has anyone else had this problem? The inner wheel was just covered in gear oil. I just pulled the shaft and the old seal. The passenger side is fine, not a drop of oil. I RTV around the seal and installed it. I also cant find the part number to that seal anywhere. Ill call EPP tomorrow. Is this problem common? Any trick to it not ever leaking again? Im going to hope the bearing itself is fine. It was making no noise and the wheel turned easily. What to all you Moser 9" guys do to make sure they dont leak? Or should I do it like I did last time? 1 out of 2 seals aint all that bad right?
This was just covered a couple weeks ago. There are part numbers for bearings and seals in this thread:
https://ls1tech.com/forums/gears-axl...king-axle.html
Mike
Mike
Mike
Mike
So All I need is that 15142 seal. I did not put any RTV on the BEARING, just on that oil seal. So, put RTV on the bearing race and the inner seal correct?
