swap lt1 rear to ls1?
Old 07-26-2009, 05:17 PM
95maroz28's Avatar
Default swap lt1 rear to ls1?
im wanting to swap the 4.10 ten bolt out of my 95 in to the new 98 i just got. just wondering what parts do i need to swap over to fit the 95 rear in the 98 and put the 98 rear in the 95. advice is appreciated
Old 07-26-2009, 05:46 PM
SmokedOutZ28's Avatar
You will need to swap the brakes and parking brake cables with each rearend. So if you take the rear end from your 95 and put it in your 98 you will need to bring the rear brakes and ebrake cables over as well.
Also you will need to make sure the ABS setup is the same between each rear end.
IMO it would probably be easier and cheaper to just purchase a set of 4.10s for the 98.
Old 07-26-2009, 09:56 PM
95maroz28's Avatar
i believe theyre both 3 channel since theres no tcs? im probably gonna swap the whole suspension over to the ls1 so im not worried about the labor part but i should have everything to swap the brake set up off of each rear end?
Old 08-02-2009, 02:50 PM
99corvette's Avatar
The only difference in the 2 rearends are the backing plates. LS1 cars have bigger brakes. So if you wanna use the ls1 brakes just change out the backing plates. You only wanna make sure its the same rearend, for example if yours is a non traction control abs rearend, then you need to find a non traction control rearend. If you not you can take the hub rings off each axle.
Quick Reply: swap lt1 rear to ls1?
