01 Ws6 Wisconsin
01 Ws6 Wisconsin
Hey, im Bill. I just picked up a 2001 Trans am WS6 last week and figured I should introduce myself, since Im sure I will be on here alot. Does anybody here know of this car? Im from the milwaukee area, but up till about a year ago the car was in Virginia.
2001 WS6 RAM AIR TRANS AM.
Has 68752 miles and has spent all but the last 1270 miles in Virginia. Silver in color and black interior.
MODS:
Motor is an LS1 with the following installed and done:
LS7 LIFTERS
ZO6 VALVE SPRINGS
241 HEADS 5 ANGLE VALVE JOB, MILLED .030, MILD PORT WORK
1998 LS1 CAM WITH GM PERFORMANCE PUSHRODS
8.8 PLUGS WIRES
PORTED MAF, THROTTLE BODY AND LS6 MANIFOLD WITH SLP AIRBOX( FULLY FUNCTIONAL RAM AIR)
PVC MOD
PACESETTER 1 3/4 FULL LENGTH HEADERS WITH NEW O2 SENSORS
TRUE DUAL EXHAUST TUCKED NICELY UNDER THE CAR WITH AN AIR/FUEL GAUGE BUNG WELDED ON.
Transmission installed with the following:
TURBO 350 WITH 9 INCH TAILSHAFT.
HUGHES TRANS RACE CLUTCH KIT
HARDENED DRUMS
CHEETAH VALVE BODY
HUGHES 3600 NITROUS 10 INCH CONVERTER
B&M SHIFTER
HUGHES SFI FLYWHEEL
HUGHES LS1 CONVERTER SPACER
Interior has the following done:
6 POINT ROLLBAR
5 POINT HARNESS
5 INCH AUTO METER TACH WITH SHIFT LIGHT AND MEMORY
Wheels:
15x8 SUMMITRACING STARS WITH 275/60/15 BF DRAG RADIALS.
15X4 SUMMITRACING STARS WITH 205/75/15 TIRES
ARP LUGS IN THE FRONT
Rear end:
STOCK 10 BOLT
3.42 MOTIVE GEARS
YUKON AXLES
AULBURN CONE POSI
ALUMINUM COVER WITH DRAIN
CUSTOM Z-BAR SUSPENSION WITH TORQUE ARM DELETE.
NOT INSTALLED
COMP CAMS (237 INT 244 EXH .610 INT .644 EXH 112 LS) WAS INSTALLED IN AN LS1.
TSP 7.4 PUSHRODS
2 AIR/FUEL GAUGES AND PILLAR POD
8.5 REAREND FROM ZR2 THAT IS 1 INCH NARROWER THAN STOCK
MODS:
LS7 LIFTERS
ZO6 VALVE SPRINGS
8.8 PLUGS WIRES
PVC MOD
HARDENED DRUMS
CHEETAH VALVE BODY
B&M SHIFTER
HUGHES SFI FLYWHEEL
6 POINT ROLLBAR
5 POINT HARNESS
Wheels:
Rear end:
STOCK 10 BOLT
3.42 MOTIVE GEARS
YUKON AXLES
AULBURN CONE POSI
NOT INSTALLED
TSP 7.4 PUSHRODS
