To the OP, IIRC it will work, but you'll want to double check that. Just make sure that you have the crank polished and all of the clearances checked out.
more then likely the crank is balanced for 4.000 bore pistons. Everything would fit but i would bring the assembly to the machine shop to have them rebalance it.
at the time i posted that there was a spammer post above my post that has since been deleted.
