4l80e question
Old 07-31-2009, 09:06 PM
boostinta's Avatar
Default 4l80e question
I just installed a 4l80e in my 02 ta. Using the stock flywheel. Now I get a bad vibration at idle and any speed. Any ideas would be great or if any one knows a fix for it or know what's wrong with it. Thanks
Old 07-31-2009, 11:06 PM
LS1Tech Sponsor
performabuilt's Avatar
Did you replace the trans mount when you changed the flexplate?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-01-2009, 12:09 AM
boostinta's Avatar
Nope left the stock mount and stock flexplate.
Old 08-04-2009, 04:54 PM
boostinta's Avatar
guys dont make fun of me I have been pulling my hair out looking up things to find out what the hell would make this vibrate. I found the problem the rear trans mount was on backwards and needed to be modd. It hit the crossmember and once this was done it went away.
Old 08-05-2009, 12:27 AM
Q
Q's Avatar
Good that you found it. I had a similar problem. Turned out my 1998 flexplate was bent and my OEM tranny mount had given up the ghost as well. Replaced the flexplate and put in a Polytrans mount. and NO more vibration.
Old 08-05-2009, 06:43 AM
Circle-D's Avatar
Glad you got it solved. It is probably more common than you think, don't feel bad. Any problem is easy once you know the solution. LOL
Chris
Old 08-05-2009, 09:34 AM
boostinta's Avatar
thanks guys
