HELP! Balancer bolt will not stay tight
Old 07-31-2009, 09:58 PM
Nasti98Z's Avatar
Default HELP! Balancer bolt will not stay tight
Recently finished our 427 stroker, pressed the underdrive pully on, tightend/torqued the new ARP balancer bolt, eveything seemed fined, 3 days later noticed the bolt was finger tight, so I retorqued it again, this time with RED locktight, 2 days later and about 25 miles, Yep bolt finger tight again, any ideas or reasons this is happening, or any advice on keeping it tight? Thanx
Old 07-31-2009, 10:56 PM
CroonerSS's Avatar
Did you let the locktight cure?
Old 07-31-2009, 11:50 PM
Nasti98Z's Avatar
Actually not as well as I should have, but should you have to lock tight this bolt anyway.
Old 08-01-2009, 07:37 AM
vsocks1's Avatar
Shouldn't need loctite but I know many do use it. Did you check the pulley after install to make sure it was seated far enough on the crank by the GM spec?
As added insurance I pinned mine with the ATI kit so it wouldn't ever spin on the crank.
Old 08-02-2009, 07:52 AM
Nasti98Z's Avatar
Yes It is seated correctly, I cleaned the bolt, and inside the crank with brake clean yesterday, re-locktighted the bolt, let the locktight set-up for 3 hrs, and torqued it to spec, so far so good.
