Coolant set up
Old 08-03-2009, 08:54 PM
maxgee's Avatar
Default Coolant set up
Curious what you guys are running?
I was running straight distilled water with 160 thermostat with fans set to turn on at 190 and off at 185. This worked great, just swapped in another motor and running 50/50 coolant water mix and it takes longer to heat up but also longer to get back to 185 when the fans kick on.
Old 08-03-2009, 10:30 PM
elias_799's Avatar
50/50 water dexcool, with a 160 stat, fans turn on at 180 and i am still overheating if i do not have the heater on.
Old 08-03-2009, 10:58 PM
SPRAYED 01's Avatar
Im going to try distilled water and a bottle of water wetter.
Old 08-04-2009, 12:41 AM
Jimmy P's Avatar
Distilled water with just a touch of Dex cool. Just remember to switch it back to Dexcool when/if it starts to get cold in your area.
Quick Reply: Coolant set up
