Recommend me an aftermarket LS7 Flywheel
Old 08-05-2009, 07:06 AM
Pete walsh's Avatar
Default Recommend me an aftermarket LS7 Flywheel
As above GM dont have them so Im after a After market flywheel where you can still use the std clutch.
Cheers,
Pete
Old 08-06-2009, 01:37 AM
SSmokin99's Avatar
I have a brand new LS7 flywheel for sale. Actually the LS7 clutch kits all use the LS2 flywheel.
Old 08-14-2009, 03:03 AM
ws6onSLICKS's Avatar
So I just ordered an Ls7 clutch kit... and your saying that it came with an Ls2 flywheel?
Old 08-15-2009, 12:19 PM
therobman's Avatar
yes it should have which you can use on ur ls1
Old 08-16-2009, 08:58 PM
meenag01's Avatar
In an LS2 GTO you cannot use the LS7 clutch with the LS2 flywheel. You must use an LS7 flywheel. The LS7 flywheel is totally different from an LS2. It has raised ribs on the O.D., the LS2 has none. I looked at both of them today and I don't see how it would work.
If someone has a new LS7 cluch kit, can you measure the thickness of the friction disk as sent from GM? That would be greatly appreciated.
Old 08-17-2009, 10:00 AM
SPEC-01's Avatar
We offer an Aluminum Flywheel for use with the stock LS7 clutch kit. Part number SC66A-2. This unit retails for $479 and is available sirectly from us or through any of our dealers. Let me know if you have any further questions and I will be happy to assist you. Thanks,
Old 08-17-2009, 01:43 PM
SNLPerformance's Avatar
I have an employee here that we swapped his LS7 out for one of our units (obviously ) and he's got an aluminum flywheel here with around 3500 miles on it, he'll let it go cheap!
Call the shop and ask for Matt. 817-750-2000
Quick Reply: Recommend me an aftermarket LS7 Flywheel
