non hydro throwout bearing ?
Guys i'm having some troubles :
are there any non hydraulic throwout bearings lower then the one on the left ?
something like the right one ?
or are all gm v8 throwout bearings the same height ?
i can't use the right one because the diameter of the bearing surface is too small for the T56 ls1 clutch pressureplate
i need a lower one because i'm using a different gearbox and made my own bellhousing
i'm not sure from what car the left one was exactely (some manual sbc), every dimension is correct for my own bell housing, it's just too high
