Damn knock sensors, keep getting code.
I replaced the 2 knock sensors and the harness. Still getting the 2 codes for low input. Fuses look ok unless I missed one.
I am running a 02 block with 98 pcm, could this be a problem?
I replaced both of mine also and my code popped up again two days later. I need to make sure no tubes next to the intake are burned. Did u tighten both of the ks by spec? I didn't and I went by feel since I didn't have the torque spec tool. Gotta take damn intake off again
i didnt have a torque wrench either, so i put em in there a bit more than hand tight. i may just end up getting hptuners and killing the code. i cant inspect it till I do
