going from DBW to DBC
Old 08-06-2009, 12:10 PM
Convette's Avatar
Default going from DBW to DBC
I have an 02 vette motor that has a DBW TB and I don't want to bother getting a pedal and all the other **** to make that work. I want to run a cable to a cable throttle body. Also I found a wire harness for cheap from a 98 T/A. What all do I have to change in order to do this? I searched a lot but can't find an exact answer. Thanks.
Old 08-06-2009, 05:24 PM
xpndbl3's Avatar
i'm in the same boat with a 04 avalanche 5.3L motor swap going into my 88 suburban.
Old 08-07-2009, 08:10 AM
mramay's Avatar
You'll need a drive-by-cable throttle body, the appropriate throttle pedal and cable. Plus the PCM will have to be reprogrammed to remove the DBW stuff and add the DBC data.
I need a TAC (Throttle Actuator Control Module) GM Part # 12578953, if you have one and I have a 75mm TBC throttle body.
Old 08-07-2009, 08:36 PM
xpndbl3's Avatar
what does the module look like? i might have it still on my motors harness, i'll look.
Quick Reply: going from DBW to DBC
