2000 c5 vette wont shift at high rpms
ok just did a clutch swap stock one was slipping to a spec 3 with fidenza flywheel did the drill mod with new slave and car will not shift at high rpms anyone else have this problem
A few questions if I may. Did you install the shim? Where is the engagement point, relative to pedal travel? If you put it in 1st and rev the motor does the car creep forward? If you can provide some answers to this I will be better able to assess your situation and provide a resolution. Thanks!
