Best option for leak test tool
Old 08-07-2009, 11:07 AM
Johnnystock's Avatar
Default Best option for leak test tool
What is the best tool for leakdown test? ...the cheaper one too!
Should I fabricate one with some fitting from a store to save $$ because I see its worth 115-130$!!
any input is appreciate!
..and I'm a noob with the tool so what is the procedure?
Old 08-07-2009, 12:43 PM
slt200mph's Avatar
Some auto parts stores will rent tools. I bought a leak down tester at Sears a few years ago and it was not expensive...$20-$25 if my memory serves.
Old 08-07-2009, 12:47 PM
LS1-450's Avatar
I saw on Horsepower that they made one from a spark plug. I tried & couldn't get all of the ceramic & electrode out of the center, but they did. So, this might be something you want to try.
You gut an old plug & then either thread or JB weld an air hose fitting connector (or a tire valve in order to use a cheapy tire air pressure, cigarette lighter powered pump). They used an air hose fitting, the cheapy pump idea was mine. It should eventuallt build enough pressure to indicate a serious problem. Although, won't be enough for a complete test. Added it, 'cuz you asked for cheap. An air compressor fitting & use is better.
Old 08-07-2009, 01:02 PM
interesting...
thanks guys!
