Help!!incon tt!!
Help!!incon tt!!
I have an ss with the incont tt kit and in the past year my driver side turbo has gone out three times the third time I had to buy a new carthridge.Its been like three month and its smoking again not much but you can see it.Whats the deal with that driver side turbo what should i check for or what should I do or what might be causing it to go out????
Don't they use a garett turbo? If so they are normally very reliable. I would think it has to be problem with oil supply. Are you sure its turbo??? Usually smoking is not the turbo but other problems . Problem with oil drainage, problem with pressure build up in the crankcase, engine problem especially if you are on stock pistons. Incon uses scavenger pump right? Maybe its not working right?
Well my motor is fully built and I'm also running a weldon pump!I dk if its the turbo I don't have oil coming out of the exhuast but I saw a drop of oil on thelower bolt of the turbo?
