Pushrod size
Old 08-09-2009, 01:55 PM
wadelieck's Avatar
Default Pushrod size
Ok i have a 99 camaro ls1 and i am going to put in a 230/240 duration 631/631 lift and i was needing to know what size push rods i need? No head work just what is listed in sig.
Old 08-09-2009, 10:44 PM
wadelieck's Avatar
hello anyone know?
Old 08-10-2009, 06:56 PM
JPH
JPH's Avatar
7.400s will work fine bud.
Old 08-11-2009, 02:34 AM
wadelieck's Avatar
what is stock size?
Old 08-11-2009, 02:43 AM
wadelieck's Avatar
and should i just hand turn the motor over when i put them in to see if it clears?
Old 08-11-2009, 02:42 PM
JPH
JPH's Avatar
Originally Posted by wadelieck
what is stock size?
7.400s. Put them in and start torquem them down to 22ft lbs, but stop on the ones that are opening the valves while you are tightening them. Then when there all tight, roll the motor over a few times and recheck that they all are tight at 22ft lbs.
Old 08-11-2009, 02:51 PM
wadelieck's Avatar
ok i am just worried when it expand the valves will hit.
Should i be i meanis it going to be that close?
