Clunking noise in reverse!!
Old 08-10-2009, 04:52 PM
flatbird's Avatar
Default Clunking noise in reverse!!
Alright, when I put it in reverse a clunking noise can be heard and felt only when an appropriate amount of throttle is applied. When i back out super slow and easy there is no noise. I've replaced both mounts as well as my transmision mount. Would being in reverse cause the motor to torque opposite of when in 1st, 2nd ect? Let me know what you think!!
Old 08-12-2009, 09:11 PM
joshp14's Avatar
Where is the noise coming from? Have you checked the u-joints?
Old 09-08-2009, 12:04 PM
flatbird's Avatar
Default mounts
The u joints have less than 10000 miles on them but i really dont think thats the problem. I just replaced the old mounts with poly and the only thing i can think of is that i didn't torque the bolts down enough. Does anyone know the ft lbs specs on them?
Old 09-08-2009, 02:50 PM
99monguse's Avatar
A4: Trans mount to trans-Tighten the bolts to 25 N·m (18 lb ft).
Trans support to vehicle-Tighten the bolts to 90 N·m (65 lb ft).
Nut that secures the mount to the transmission support-Tighten the nut to 57 N·m
or 42 lb ft,
M6:Trans mount to trans-Tighten the transmission mount bolts to 48 N·m (36 lb ft)
Trans support bolts-Tighten the transmission support bolts (2) to 90 N·m (66 lb ft).
Trans mount nut-Tighten the transmission mount nut to (2) 105 N·m (77 lb ft).
Old 09-08-2009, 03:29 PM
flatbird's Avatar
Default mounts
Shoot man, i was refering to the motor mount ft lbs. I'm stumped so far.
Old 09-09-2009, 05:37 PM
Fireberg's Avatar
Make sure that the two bolts / nuts that secure the torque arm to the differential case are tight. If I recall I think they should be at ~ 90 ft/lbs.
Quick Reply: Clunking noise in reverse!!
