Throttle Cable & Bracket Issue
I was driving along today, and my gas pedal dropped off and sat on the floor. I opened the hood to see my throttle cable off of the throttle body. It sits very loosely in the bracket.
Anyone else dealt with this? How to you get it to say on the bracket better?
Thanks!
Thanks!
If the clip is broke then I would buy a used cable from a salvage yard. Another option would be to JB Weld it on. If you go that route use JB Weld not JB Quick. Then let it sit for 24 hrs to fully cure. You could then pain over the epoxy with black paint so that it doesn't stand out.
Wait. Are taking about it comming off of the throttle cable bracket or the throttle body butterfly bracket. If it's the throttle body butterfly braket and you have traction control then you can adjust the tension and length of the cable where the two large black clips are on the cable lines comming from the firewall. They should be between the ac accumulator and the firewall on the passenger side. Just pull the clip off and pull on the cable untill it's tight then re clip.
