n2o not working first couple trys
Old 08-16-2009, 12:02 AM
00silverGTP's Avatar
Default n2o not working first couple trys
the last 3 or 4 times I have had the car out and used the spay it will not work the first couple of runs. pressure is fine, purge it, then it just dosen't work. the second time it works a little. then it finally on the third run it hits like it should. any ideas?
Old 08-16-2009, 01:26 PM
dnkynrbk's Avatar
Has to be a wiring issue you may have a bad ground. What kit do you have and what controller?
Old 08-16-2009, 03:58 PM
HSW plate kit. dyno tune window switch. I will go through all the wiring, jsut to check.
