4 speed clutch
4 speed clutch
Im looking for a clutch that is capable of supporting upwards of 550HP, Ive heard from quite a few people that they like the Centerforce Dual Friction, it relatively cheap too. Some have said you can run a 12" with no modification also, and if that's correct, that sounds like the way to go. I need a billet steel flywheel too. Will a flywheel of a different brand of the clutch be fine?
The Ram flywheel on jegs is about 75 bucks cheaper and 4 lbs. lighter than the centerforce. Trying to get this sucker goin quick as i can. TIA.
