Any install tips for 5177?
My 5177 kit will be here tomorrow and im going to try and put it on when I get home from work. You guys have any tips that might make this install easier? Or any precautions that I need to take before spraying for the first time?
Thanks, Justin
Thanks, Justin
I was unable to place my 15lbs bottle in spare area, so I mounted it in the boot sideways and tilted 45o so the inner pick up tube will be able suck fluid N2O even at acceleration (It's in the install diagram as a mounting option). With a heater i've had no problems yet. The nice thing about a dry system is if you run out of juice, the MAF readjusts and does no adverse effect on engine.(You'll justy finish the race N/A).
Originally Posted by chevyzz8
is it ok to spray through shifts on an A4 or do those need the window switch also?
Originally Posted by CLB3RD
on the stock LS1 tranny...NO. That will really mess your transmission up lol. I ran mine from the spare tire , under the carpet then up through my door to my fender well...then just ran it into my cold air...it was a good setup.
Of course I only have 35K on my tranny, take mileage in consideration.
