CPP or Perf. online big brake set up anyone use it?
CPP own put together setup I am looking at the setup for 64-72 A body
13" front with 52mm twin piston PBR calipers
12" rear w/lincoln continental style calipers
Drilled,slotted,zinc washed
all hoses,cables,brkts,hubs bearings,master,prop
1498.00 seems like a pretty good price for what ya get versus a couple of the other guys. plus the rear setup is avail for 10/12 bolts and 9"
Performance online has a set up fairly similar but it will cost about 200 more + for their set up
theirs 38mm 2 piston PBR front and PBR rear
Just looking for any input on these if anyone has used one of these setups versus the wilwood or KORE3 K3 being rather expensive and limited to 10/12 bolts for the rear
