bolts keep backing out on Torque arm
Old 08-20-2009, 04:01 PM
NavdeepWS6's Avatar
Default bolts keep backing out on Torque arm
do you have any tricks on how to keep the bolts from backing out on a moser 12 bolt with the UMI torque arm.
they are put in with red loctite but still backed out after a hundred or so miles
actually i am missing one and ordered a new set
Old 08-20-2009, 04:15 PM
Bad Blue WS6's Avatar
when you installed the TA on the M12, did you blow/clean the holes out B4 screwing in the bolts? I only ask cause i used to have this issue until i cleaned the holes out well (there was dust and other crap down there that kept them "loose", once i blew them out with my air compresser, i no longer had the issue. Mine are also red loc tite-ed, and were just looked at about 3 days ago with no issues. Im using a BMR TA.
Wayne
Old 08-20-2009, 04:24 PM
01ssreda4's Avatar
Install them with a Lincoln welder
Old 08-20-2009, 04:29 PM
WYATT318MOPAR's Avatar
That is exactly what I was getting ready to say...When locktite fails weld it
Old 08-20-2009, 07:01 PM
xXxSilveradoxXx's Avatar
Drill the bolt and use a cotter pin. That's what I would do.
Old 08-20-2009, 07:11 PM
Formerly darynC-10/23/10
Daryn's Avatar
either a cotter pin or double nut them
Old 08-20-2009, 10:12 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Double nutting on a Moser 12-bolt is impossible - so is putting any sort of nut on the mounting bolts. They are four short bolts that go into blind holes, hence the problem. **** poor design, but that's what people have to work with when they have a Moser 12-bolt.
Old 08-20-2009, 10:14 PM
Oh, they are bolts that go into a blind hole? Could the bolts be safety wired?
Old 08-21-2009, 04:46 AM
EPP
EPP's Avatar
Yes they could be safety wired. Bob
Old 08-21-2009, 04:52 AM
Then that is what I'd do!
Old 08-21-2009, 05:07 AM
NavdeepWS6's Avatar
ok thanks for the tip on safety wire how exactly would it work
Old 08-21-2009, 05:43 AM
Jimmy P's Avatar
Have you tried cleaning out the bolt holes very well? How much locktite are you using? If you are using a ton of locktite, on bolt holes that are already saturated with dirt and old locktite, it wont do much good. I used to have this issue when I had a moser 12 bolt a few years ago. I just cleaned out the bolt holes VERY WELL, I think I used mineral spirits or something like that. Dried them out very well, then put a couple of drops of l red locktite on each bolt, and didn't have any issues since.
Old 08-21-2009, 07:56 AM
Intercooler2's Avatar
Bolts with Nylock patches. Other option is like stated with a tack weld.
Old 08-21-2009, 01:27 PM
wrd1972's Avatar
If it were me, I would drill a hole in the heads and wire them together somehow.
I cant believe Moser put blind bolt holes in the housing for attaching the TA. Thats just retarded. They should have used the roughly 8" long bolts just like OEM.
Does the strange do this too? Or do they use the long bolts?
Old 08-21-2009, 02:32 PM
Just like #1
Old 08-21-2009, 03:32 PM
BMR Tech's Avatar
Strange uses a thru bolt system just like the OEM 10-bolt...
Old 08-21-2009, 03:36 PM
BMR Tech's Avatar
I have used this method several times and never had an issue.
I usually use brake cleaner to get all of the oil out of the holes and off the threads on the bolt. Take and blow the holes out till they are clean and use the red Loctite no more problems ....
Old 08-21-2009, 05:34 PM
NavdeepWS6's Avatar
ok ill try that when i get my new bolts and will the mineral spirits clean out the old loctite also
Old 08-21-2009, 06:21 PM
Jimmy P's Avatar
Now that I think about it, I might have used a thread chaser as well.
Old 08-21-2009, 06:43 PM
NavdeepWS6's Avatar
lol thanks for the help guys
Quick Reply: bolts keep backing out on Torque arm
