magnacharger mp112
magnacharger mp112
I bought a magancharger from a member on here and I am kind of confused on the fuel part. IT is for a 2003 hummer with a lq4 and I have an lq4 in an 88 suburban but its an 06 lq4. In the directions it talks about connecting a hose to the fuel inlet on a little regulator or something. I got the inline fuel pump for it. Do I put that in after the in tank fuel pump? Any help is greatly appreciated.
On that kit the fuel rail should have block that bolts to the rail. The block will have provision for the Fuel inlet and return as well as a small regulator with a 1/8 in hose that goes to Manifold.
If you download the install manual from Magnacharger its very clear to see.
Here's a link to the manual
http://www.magnacharger.com/pdf/manual-HummerH2.pdf
