Vibration at 2200 RPM
I have an 05 V with 63k miles on it. There is a vibration from 2200 rpm up to 2500rpm, it feels like a tire off balance, but it happens even if the car is in stopped, with the brake on in neutral. There is no difference wether the clutch is in or out, also happens while driving. What could be causing this?
Just a guess, mind you, but pop your hood and watch the harmonic balancer while someone revs the motor up to 2500 RPM. Could be something else, but that's what I'd do first anyway.
Good luck.
Good luck.
