Turbo 6.0 what power to expect
Old 08-22-2009, 08:38 PM
brandon1566's Avatar
Default Turbo 6.0 what power to expect
It's stock truck motor truck intake with t70 master power turbo 60lb injectors, a1000 fuel pump synapse 50 mm waste gate at 10psi through a t400. I'm curious what power I should have. Debating on a futral f12 cam in the future
Old 08-22-2009, 08:45 PM
73 nova guy's Avatar
i am all ears im running the same setup
Old 08-22-2009, 09:12 PM
TX RED's Avatar
500hp you should post over on the FI section
Old 08-22-2009, 11:09 PM
ParkerTPIz's Avatar
i was reading a bit on this last week. i found that at 10 psi you should achieve anywhere from 50-60% hp gain.
Old 08-22-2009, 11:13 PM
jermzz's Avatar
Old 08-22-2009, 11:25 PM
Adam Connell's Avatar
The cam will make or break your numbers... used z06 cam is good, but a good aftermarket cam will sound a hell of a lot better. I really enjoy how the EPP blower cam sounds and the numbers are very nice as well.
